Driver keeps crashing when playing games - 2x 290's
Not really the best way to get help.
Show us a Unigine Valley ExtremeHD score.
Just having a nightmare of a time -_-
Do it again but this time have your gpu overlays running as i instructed you in the other thread.
EDIT
That score looks about right i think btw.
EDIT
It is, I checked it earlier against other 290Ps and also did a stock run on two 290Xs to compare.
It could be the CPU setup, if that is not stable you get a lot of crashes in Heaven 4.
It crashes in everything Kaap games just randomly at desktop.
The cpu is stable its running at stock and has never caused a problem.
The driver just crashed as I was typing this.
It just randomly stops responding.
Sounds like one of the gpu's is faulty then. Test them each individually.
They were thoroughly tested by Toxicbag on the forums before I even got them.
I've tested them both, I guess Ill test them one by one.
Thing is though its really random I could go half hour without it happening.
Ive even ran entire heaven benches without it happening.
Its happened again while typing this.
I flipped the bios switch on the cards - I have managed to get through the heavens benchmark without a crash so far.
Btw the overlay does not get capture in the screenshot when I hit F12 and if I use print screen it only captures the desktop -_-.
