- 25 Apr 2010
- Ipswich
AS:LOKNDAL:KJSNDALK:JSND
14.1 beta drivers? Common problem, go back to the 13.12 whql drivers.
Not really the best way to get help.
Show us a Unigine Valley ExtremeHD score.
	at the risk of sounding like a parrot because ive repeated it so many times, disable ulps
Its disabled -
The driver still crashes a lot.
I will run it again with the overlay.
Do it again but this time have your gpu overlays running as i instructed you in the other thread.
EDIT
That score looks about right i think btw.
The driver crashes when running Heaven? What driver are you using? Are you overclocking?
13.12 Latest none beta.
No i am not overclocking, it just constantly crashes -_-.
It could be the CPU setup, if that is not stable you get a lot of crashes in Heaven 4.
It crashes in everything Kaap games just randomly at desktop.
The cpu is stable its running at stock and has never caused a problem.
The driver just crashed as I was typing this.
It just randomly stops responding.
So it crashes when running Heaven? Or does it just crash when playing a specific game? Have you tried each gpu on its own?
Sounds like one of the gpu's is faulty then. Test them each individually.
It crashes in games or at desktop level. It could be while doing anything.
