- 4 Oct 2005
- Herefordshire
I am using the following in my sig and was wandering since I am a usb header short, due to one being filled by the h100i usb connection.
Do you have to use this usb ?
How many people use the software and is it any good(corsair link) ?
Can I connect the usb header once set it up (ie fan speed) then disconnect the usb header and then disconnect the usb header. then plug in a usb cable from my case so I can sue all of my usb ports on the front of my case ?
is there a better alternative ?
Thank you for the advice
