EVGA SuperNOVA NEX750B 80+ Bronze
Hi, l have the EVGA G2 1000W Gold PSU and thats based on the SuperFlower Leadex 1100W Platinum PSU, can't fault it at all.
Its always best to read some reviews about your PSU you want to buy, to give you some idea how it performs.
It is certified for a 2 way SLI with Titans so should also be good for the 280s http://eu.evga.com/articles/00722/
Hi, using the EVGS G2 1000W Gold l take it these results giving on your link are for everything running at STOCK nothing overclocked?
To be honest l would not put more then 2x780 Ti or Titan's at the most giving headroom for overclocking > CPU+GPU's on my Build see sig below with the EVGA G2 PSU.
No.. look at the results they are for his 750W Bronze EVGA power supply..
the psu is fine if it isnt then just ask him for a refund and tell him to refund it .. at £40 its a steal for a new evga psu
If it is faulty you can also handle RMA with the unit. On those PSU is a 5 year warranty related to the product not the user...
wow really? i mean most people who buy second hand to tend to RMA it anyway (e.g people buy 2nd hand corsair prods, use the invoice and RMA it using original purchaser ID).. so I guess you might as well have made that move anyway.
thanks, its good to know that dominik.. evga has opened my eyes :)
