- 27 Mar 2013
- Lincolnshire
I noticed that all cars in Poland had their lights on 24/7 too. Seems like a good idea to me.
I cannot turn on my rear fogs without also turning on the front fogs. Golf MkIV.
I think we have to come to terms with the fact that most people don't care about car maintenance and will do the minimum to get by, sometimes less until they're called on it (read, pulled over or MOT).
As for those with poor sidelights, they probably don't even know as they're usually in the car when they're on. This only seems to be an issue with older vehicles, so will go away.
My main bugbear with lights now is those running around with their headlights as high as possible at some crazy unnecessary level of brightness. I notice a lot of new German cars have needlessly bright headlights. They blind me when I'm driving the go cart, especially when poorly adjusted.
Good point, same in my Mazda. Can't remember if that was the case in my Astra though.
I've had both my headlights go in a week,
as it was peeing down all week I wasn't inclined to fix them
Done now though.
Yep,
People think that having headlights on make you more visible, which it does to an extent.
BUT, it also destroys any distance perception, so yes I can see you but I've now less of an idea how far away you are or how fast you are travelling.
All I can see is the equivalent of lens flare.
Some research on this would be nice. Save us from cars lit up like a disco ball.
Lens flare? Last I recall I wasn't driving through a J.J. Abrams movie
On a more on point note though, some are bright but I've never found it a problem? The only ones that I find glaring are the ones that are clearly misaligned or aftermarket rubbish.
Rules I live by:
If wipers are permanently required - Dipped beam on.
If sidelights are needed - Dipped beam on. Absolutely no point running sidelights only.
Periods of darkness - Dipped beam on, main beam in all possible situations.
Main beam not used when - Observational advantage to be gained without them (seeing oncoming headlights around bends, from junctions etc). Using them would dazzle other road users. There is no advantage to be gained (Highly illuminated areas.)
I was always taught that you aren't actually supposed to drive on sidelights anyway as they are only meant for marking your car when parked.
Whether thats true or not I don't know but like you if I need my lights I put them straight to dipped
I try keeping this in mind when someone is behind me though.
Some modern brake lights are far more bright than is needed, especially when people insist in keeping the foot on the brake in an urban traffic queue at night.
It's the other way round in Mazdas isn't it? Can't turn on front fogs without turning on rear fogs first. Explains the number of idiots I've seen driving around with a single rear fog light on thinking they look all cool because they have their front fogs on.
Not in mine (3 Sport) I don't think, there's a 'ring' on the indicator stalk that you click forward one position for front fogs, then push forward again (which then returns back to the previous position) for the rear fog light. If you click it back to 'off', it turns them both off.
I may go and check that that's correct though...
