***The Vapers Lounge***
Status
Not open for further replies.
Awesome, a Vapers lounge! Been Vaping since March last year totally given up on the Tobacco.
Just bought myself a nice Provari Mini and a Vision Eternity Tank to replace my old VgO2, and it's really good :D I prefer the fruity flavours and get my juice from JacVapour who do some excellent UK Made flavours, Banana Milkshake, Strawberry Chew(its), and Raspberry my current favs.
BTW My Provari didn't come with Batteries, anyone else get one with them?
Looking to purchase the following to start out.
AnyVape Davide BDC ASPIRE Tank
AnyVape eGo Twist VV battery - 650mah - silver
AnyVape eGo Twist VV battery - 1000mah - silver
USB eGo Charge cable
WizMix E-Liquid - Menthol Asylum - 10ml / 12mg
Anything I am missing, or better off getting?
Welcome :)
Most tube mods won't come with batts unless you get a kit, so that's fairly normal.
I wouldn't bother with the 650mah, and would just get 2 x 1000mah batts.
I also am not a fan of usb chargers as my main charger, and recommend a decent mains charger to make sure your batteries and usb ports don't go pop.
Other than that, looks good. Twist batts are good and cheap, BDC atty should provide some good oomph, and menthol is a great starter flavour.
That ego charger can be plugged into any phone charger plug that has a USB socket thingy in it. The bats will charge from the mains and charge much faster then using a USB socket on your PC. Happy days. You can also get an adaptor for a car ciggie lighter socket that you can plug the charger into and charge in your car. Its any iphone or android phone 12v socket to usb plug whatsitdoojit and you can get them for about 4 quid on amazon.
If you haven't actually used it can't you return it under DSR?
And yes you're right sorry it was vape tank not vapegear.
Good point. I tried ringing him just now but he's away till monday and has closed his ebay shop till then. Problem is, I received it on the 5th Feb so I'm well over the DSR timelimit I think by about a week? I can only hope he might be nice and take it back. Somehow doubt it.
Just thought I would post this for anyone interested in a new ecig or one which does not matter if it gets lost, broken etc. Cheap setup which works well....
Kanger EVOD 1000mah battery(s) - £10
Cloud9Vaping Micro-D RDA (full stainless mini dripper inc. SS drip tip) - £10
Organic cotton and 1.8ohm microcoil - pennies.
Ok so probably not as good as a Kayfun and provari or anything like that and not as shiny and nice to use obviously but at £20... it is a bargain. I had protanks, spinners, vamo, IGO-W, AGI etc. and I would say this beats the protanks easily and is not far off the vamo + IGO-W, as long as you get a 1.8 ohm coil the 3.7v EVOD will be about 7.5-8w which works well.
I am thinking of getting a Nemesis mod + kick + RBA at some point but for the amount this cost I am happy with it. £20 for the dripper, 1000mah EVOD and a bit of cotton and .2 kanthal and you are good to go. Definitely recommend this over a protank 2 mini if you don't mind making your own coils and dripping. I don't think it is possible to get better performance for £20.
This post deserves a:
Reason I looked at getting a 650mah as well as the 1000mah was down to the size. The 650mah seems a bit smaller and thought it would be handier on a night out.
Would you or anyone recommend carrying something different for nights out?
I know what concentrate I want but it's the nicotine thing I'm baffled by. where can I get vg or pg that's ready made up at 12mg strength of nicotine?
Have you tried playing with one of the juice calculators?
http://www.todmuller.com/ejuice/ejuice.php Put the VG in were it says water. There are more complex ones out there but this was one of the first and I've just kept using it as it does everything I want.
If you bought unflavoured already at 12mg (don't know anywhere that does this) it would be less when you added the flavouring. It is really easy when you get used to it.
Say you bought 72mg base in PG and wanted 50/50 PG/VG with 15% flavouring you'd mix
1.7mls base nicotine (72mg base I'm using here)
1.8ml of PG
5mls VG
1.5mls flavouring
To be honest with the ego batteries 650mah probably run out half way through your night out so you would need 2, making it bigger than 1 x 1000mah.
Cheers for that.
Would I be better off looking at mods then for a more compact device?
I'm really new to all this but have been trying to gain an understanding without actually purchasing!
I only smoke when I have had a beer (i'll possibly have one or two on a standard weekend), I'll smoke a pack of 20 on a night out which is no more than once a fortnight.
Cheers for that.
Nah, 1000mah twist batts would be fine. I would always recommend carrying a spare battery with you anyway, and they are very small as it is. a 1000mah ego battery with an atomiser on it is roughly the size of a small cigar, and fits nicely in the pocket with a bottle of liquid.
Yay! Vapemail!
Told you I have fallen for the drippers :) Its a Luxe Mods Hybrid Dripper with the 18350 Mech Mod. Thing of beauty and made in the UK!
I have put it in next to a Kayfun Lite for scale - this thing is tiny!
Status
