Project: mit kleinem Formfaktor
that braiding looks nice ;)
the parvum lads are very patient buddy, they are hella busy at the moment though, im actually holding off pestering them at the moment for some things i want them cut for me!
they are going to have to start looking into a bigger warehouse and hiring more staff at the rate they are expanding haha!
Whats the little plastic crimp device your using on the cables snips? Could do with something like that for mine.
its a cable comb i had knocking around here, i used it just to hold the cables together whilst i took the picture (its a 24 pin comb, holding 14 wires there, which is why it looks a little funny, you can get them for 4,6,8 or 24 pin connectors.
if you pop me an email il sort you out ;)
Ahh cheers mate, mail sent.:)
I ordered it over the phone from Overclockers. S2 is correct, its a new revision with improved features. USB3 as standard and a scratch resistant side window.
also has litte feet built into the case, its slightly different in dimensions to the S1.0 and has a different method for attaching the HDDS.
sorry for the blurry picture.
Just had the most amazing email - "Your order has been shipped"
My Friday just got better!!! Bring it on!!!!!!!!!!!!!!!!!! :D
