- 6 Aug 2009
- Wales
Edit, wrong esttings used
how do i change them on the benchmark guys?
how do i change them on the benchmark guys?Well locking it to 1920x1080 does not mess up my screen and totally kill performance like it does in Heaven, so this is 1920x1080 again no OC on POS CPU.
Good guesstimate BTW.
Sniper Elite V2 Benchmark Report
Created: 2014-02-22 at 18:30:13
Build Version: 1.05, Jun 7 2012
Average FPS: 61.3
Minimum FPS: 23.6
Maximum FPS: 230.7
Number Of Frames: 4693
Average Frame: 16.308ms
Minimum Frame: 4.335ms
Maximum Frame: 42.378ms
Machine Name: jh30uk
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 16322MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX 780 Ti
Feature Level: DX11.0
Driver version: 9.18.13.3489
Dedicated VRAM: 2963MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Advanced Shadows: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Compute Shaders: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
It hard to catch screen on time for the Standalone Bench as it closes real fast.
Thanks, was actually Core 1267mhz in both tests but boost raised a bit as it ended when results came up and I hit screen capture.
290X does seem to struggle in this compared to 780ti's and Titans, your build is different to the one i tried Greg and you use Windows 7, i doubt very much though it would make that much difference.
Ah well, you win some and lose some![]()
