Sniper Elite V2 Benchmark
1440P
4960 @ 4.7 (water)
780Ti ref SC 1250/1925
Sniper Elite V2 Benchmark Report
Created: 2014-02-22 at 23:20:30
Build Version: 1.05, Jun 7 2012
Average FPS: 108.3
Minimum FPS: 9.5
Maximum FPS: 637.6
Number Of Frames: 8282
Average Frame: 9.231ms
Minimum Frame: 1.568ms
Maximum Frame: 104.982ms
Machine Name: MICHAEL
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 32707MB
CPU: Intel(R) Core(TM) i7-4960X CPU @ 3.60GHz
Number of Cores: 12
GPU Name: NVIDIA GeForce GTX 780 Ti
Feature Level: DX11.0
Driver version: 9.18.13.3489
Dedicated VRAM: 2902MB
Resolution Width: 2560
Resolution Height: 1440
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Advanced Shadows: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Compute Shaders: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
I'm done now Jesus. :D
1440P
4960 @ 4.7 (water)
780Ti ref SC 1316/1965
Created: 2014-02-22 at 23:29:19
Average FPS: 40.6
Minimum FPS: 13.7
Maximum FPS: 159.4
Number Of Frames: 3106
Average Frame: 24.639ms
Minimum Frame: 6.272ms
Maximum Frame: 72.912ms
Monitors: 1
System RAM: 32707MB
Number of Cores: 12
Dedicated VRAM: 2931MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
7970 @1230/1660
[email protected]
Created: 2014-02-23 at 02:37:20
Average FPS: 38.0
Minimum FPS: 23.1
Maximum FPS: 82.0
Number Of Frames: 2911
Average Frame: 26.302ms
Minimum Frame: 12.195ms
Maximum Frame: 43.277ms
Machine Name: PC
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 8152MB
CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Number of Cores: 8
GPU Name: AMD Radeon HD 7900 Series
Driver version: 8.17.10.1267
Dedicated VRAM: 3054MB
Resolution Width: 1920
Resolution Height: 1080
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
The best I can do for now, cannot OC CPU and AB is buggy for Ti for now so tried Precision but voltage falls back to 1.15v a lot and goes to 1.20v max.
Same voltage as it can do without AB/Precision and that crappy KBoost crashes PC same as last build so not same hardware.
Card is only 2days old and need to let it settle, learn the new setting and then look at Bioses with 1.21v etc.
This is my best I can get.
Core in test (not at end) 1283 and Memory 1900
Created: 2014-02-23 at 03:44:05
Average FPS: 63.2
Minimum FPS: 20.9
Maximum FPS: 206.4
Number Of Frames: 4838
Average Frame: 15.834ms
Minimum Frame: 4.846ms
Maximum Frame: 47.746ms
Machine Name: jh30uk
Monitors: 1
System RAM: 16322MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
Dedicated VRAM: 2963MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Don't forget to post the settings please.:)
Wind the VRAM up a bit and that should get you over the 100.
Oh bugger knew I'd forget something, will do another run later, 1202/6600 os fairly tame for my cards, though not sure how much more vram speed my elpida card has to offer :D
The settings should still be in your Documents\SniperEliteV2_Benchmark folder.
another attempt, GPU's set to boost to 1241/6890 (near 7ghz on an elpida card, result :)).
The top card was bumping off of the power limit thus throttling, so spent a good portion of the bench at around 1150mhz....
Created: 2014-02-23 at 11:02:21
Average FPS: 103.5
Minimum FPS: 26.8
Maximum FPS: 474.6
Number Of Frames: 7924
Average Frame: 9.660ms
Minimum Frame: 2.107ms
Maximum Frame: 37.321ms
Machine Name: PAUL
Monitors: 1
System RAM: 8146MB
Number of Cores: 8
Dedicated VRAM: 2950MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Someone needs to do something about this :p
4 GPUs
1. Score 174.3 GPU 290X @1000/1250, CPU 4930k @4.0, Kaapstad Link
2. Score 173.7 GPU nvTitan @837/1502, CPU 3930k @4.0, Kaapstad Link
3. Score 114.5 GPU 690 @915/1502, CPU 3960X @4.0, Kaapstad Link
4. Score 48.8 GPU 5970 @725/1000, CPU i7 975 @3.46, Kaapstad Link
Will have a run of this later. Is the game any good lol?
Just thought I would give this a run with a memory overclock at 1440P to see if it makes much difference.
Created: 2014-02-23 at 11:19:10
Build Version: 1.13, Apr 11 2013
Average FPS: 62.8
Minimum FPS: 6.7
Maximum FPS: 653.0
Number Of Frames: 4806
Average Frame: 15.930ms
Minimum Frame: 1.531ms
Maximum Frame: 149.128ms
Machine Name: GREG-PC
Monitors: 2
Operating System: Windows 7 Ultimate Edition Service Pack 1 (build 7601), 64-bit
System RAM: 16328MB
CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Number of Cores: 12
GPU Name: NVIDIA GeForce GTX TITAN
Dedicated VRAM: 3072MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
SLI Titans at 837/3719 - 3930K at 4.626
Created: 2014-02-23 at 11:53:58
Average FPS: 56.6
Minimum FPS: 25.4
Maximum FPS: 402.1
Number Of Frames: 4329
Average Frame: 17.669ms
Minimum Frame: 2.487ms
Maximum Frame: 39.308ms
Monitors: 2
System RAM: 16328MB
Number of Cores: 12
Resolution Height: 1600
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Thought I would do a 1600P run (in case you add it)
SLI Titans at 837/3719 - 3930K at 4.625
Hi,
Here is my crossfire run on 290p's Sapphire trix stock @ 1000/1300 with i5 3570k @ 4.3
Created: 2014-02-23 at 12:27:01
Average FPS: 85.8
Minimum FPS: 30.0
Maximum FPS: 750.4
Number Of Frames: 6570
Average Frame: 11.660ms
Minimum Frame: 1.333ms
Maximum Frame: 33.327ms
Machine Name: STEVE-PC
Monitors: 3
System RAM: 8152MB
CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Number of Cores: 4
GPU Name: AMD Radeon R9 200 Series
Driver version: 8.17.10.1247
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Seems ok, to me, do you need a pic as well?
Greg where did you find your version of the benchmark?
All i can find is 1.05:(
(forget what i had just put here) for some reason i thought i was also on 1.05 on my first run, however it appers im also on 1.13, the current steam version is that number, very odd
Created: 2014-02-23 at 12:55:28
Average FPS: 85.4
Minimum FPS: 25.1
Maximum FPS: 786.7
Number Of Frames: 6538
Average Frame: 11.715ms
Minimum Frame: 1.271ms
Maximum Frame: 39.783ms
Monitors: 3
System RAM: 8152MB
Number of Cores: 4
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
