Thanks does this really make that much of a difference? And what's all the talk about servers and do you need a external hard drive for these?
Speed wise yes, the menus are slightly faster as the artwork is saved too it, that's about all
For the set up i need a mouse and keyboard, can i use my wireless mouse and keyboard to set it up or would i infact need a proper one?
Can any Wireless nano usb stick be used with the Pi as i would much prefer it being wireless.
Are there any SDHC cards that dont work with the pi and is a cheap Fleabay 8gb class 10 sufficient?
Do i need an external hard drive?
What size and speed of USB stick would be sufficient to load from a USB?
Your wireless one should be fine to set up with but check http://elinux.org/RPi_USB_Keyboardss
There are certain compatible devices, check http://elinux.org/RPi_VerifiedPeripherals#USB_Wi-Fi_Adapters
http://elinux.org/RPi_SD_cards
Where is your data stored? Mine is on a NAS drive in the office and I stream from that over my network
I have a 16gb usb 3.0 from a competitor that works flawlessly
If you need your laptop on, then why not just use your laptop? You will get much better xbmc performance from that.
I made a custom remote.xml file and placed it in:
Linux: /home/<user>/.xbmc/userdata/keymaps/
Code:<keymap> <global> <remote> <red>XBMC.ActivateWindow(Home)</red> <green>Info</green> <yellow>OSD</yellow> <blue>ToggleWatched</blue> <title>PreviousMenu</title><!-- Return Key on Samsung Remote --> <guide>ContextMenu</guide> </remote> </global> <FullscreenVideo> <remote> <blue>ShowSubtitles</blue> </remote> </FullscreenVideo> </keymap>
That way I can use the red button to go to home screen. You could also set up a key to toggle fullscreen http://wiki.xbmc.org/index.php?title=Keymap
<keymap>
<global>
<remote>
<Exit>XBMC.ActivateWindow(Home)</Exit>
<green>SkipNext</green>
<yellow>SkipPrevious</yellow>
</remote>
</keymap>
So if im happy with all the other settings and I just want return to home screen on my "Exit" button that currently does nothing its just a case of
Code:<keymap> <global> <remote> <Exit>XBMC.ActivateWindow(Home)</Exit> <green>SkipNext</green> <yellow>SkipPrevious</yellow> <blue>ToggleWatched</blue> <guide>ContextMenu</guide> </remote> </keymap>
And I seem to have no next and previous to skip between say music tracks.
So to stream from my Laptop to a Rpi i'd need the laptop on? so your suggesting if thats the case i would be better just using my laptop and using a HDMI cable? I just had a idea of having a device under the TV and being able to just turn it on and use when i please without the idea of dragging a laptop out.
Yeah your laptop would need to be on to share the files.
RaspPis, NUCs etc all make a lot of sense if you have some form of central file storage. So for example I run a server in my garage, sharing all my media. I then have a couple of NUCs and PIs dotted around the house so I can access it in a simple and wife friendly way. Allowing us to watch and resume on any TV. My server also runs a plex server so I can watch/listen to my media on mobile devices and when out and about.
Now with your setup, files on the laptop, I would probably see first if the TV (smart?) has a plex app and use a plex server on the laptop, this means no hdmi cable required (but maybe a degradation in picture quality), if not then try DLNA server and and the TV has a dlna player to play from the network.
If neither are available then I would just use a HDMI cable and propbably wouldn't even bother with XBMC.
EDIT: Or buy and external hard drive and rasp pi, or somehting more powerful depending on your requirements. Or even a NAS or Server..
I like Intel nuc in a passive case. So completely silent low power etc
