- 19 Mar 2011
Seeing as the last spec you guys picked for me has done so well, would you spec me another one please? It's mainly for gaming.
The budget is £1000 and it has to be a micro ATX. I need the case as well and this is where I'm not so confident on the choosing as I need to know everything will fit comfortably.
The case doesn't have to be anything special, as long as it has decent airflow.
So I need the case and everything in it. The person I'm building it for has a 1600x900 monitor so I suggested he got a 1080. I'm hoping the spec would be good enough to have a monitor included in the total but the main objective is to get the best components possible and hope to get a 1080 monitor included as well. If you think he could carry on with the 900p monitor, it's more budget for the components.
I might be able to adjust the budget to fit the best spec but only by around £50 more.
There's no preference for AMD/Intel/nVidia. Just the best bang for the buck.
Thanks for reading.
Thanks for reading.
