Where is the first floor?
Status
Not open for further replies.
And what about now ?
Even smaller cabin on stilts on a normal sized treadmill, or small cabin on stilts on a HUGE MOTHER****ING treadmill.
Ground Floor, First Floor, Second Floor and so on and so forth...
However, try working a job where some buildings have 6 levels, 2 being below ground level so that when you step through the door on ground level you're on what they refer to as the 3's. I still can't work out what level I'm on sometimes...
Yeah ground floor is stupid, you walk into the building, what floor do you stand on? The first one, not the zero one or any other damn thing.
I take the stairs if it's 10 floors and the building is air conditioned, free gym!
Not really.
Zero exists, and we count from it because time can be fractioned. However most things come in wholes. You don't get 1/10th or 0.1 of a touchdown, you get 1 touchdown.
And where is my Starbucks?
If I split a Starbucks into 2 mugs, is that two half Starbucks or two Starbucks?
The key words here are" above ground" which is a bit of a handful for signs and buttons but if you put that after floor all should become clear. It's what our system of numbering is based on.
Which is a problem because in many cases there can be multiple different floors at different heights that are all ground floor wrt local ground level.
A much more logical system is to label the lowest floor 1 and increment upwards.
In a building, it has floors, the difference between each floor is on the Y Axis. Therefore, in order to increase the count from one to the next, the simple logic would require you gain a floor, which means movement on the Y Axis. The correlation in changes in the number of floor is as a direct result of changes of the Y Axis.
To illustrate this. You go from the 5th floor to the 6th floor, you go up in the direction of the Y Axis.
Stepping through a door into a building last I checked is a change on the X Axis, not Y Axis.
To illustrate this, look at your door in the room you are sitting in right now, on the other side of that door is still the same floor without changes in the Y Axis. If you are sitting on the ground floor, the other side of the door is the ground, again, without any changes in the Y Axis.
Therefore, if it has no change in the Y Axis, and no change in floors.
You are on the ground outside the building and you are still on the ground inside the building. I do not call the pavement the 1st floor, I walk on the ground.
Ground floor = ground.
It cannot get any simpler.
Calling the ground floor also the first floor and if you step inside the building merely because you walk through a door just complicate things pointlessly. I know it is just a labelling at the end of the day but a needless exercise to change something that is so logical to begin with.
Which is where 0 comes in instead of G lol
I see what you mean though. Blame builders and plan diagrams they are not in 3d :D
Status
