I was tempted by the idea, but then read a lot of poor reviews of it:
http://www.techspot.com/review/781-amd-a10-7850k-graphics-performance/page7.html
Appears to be very different depending on the title and whether crossfire is well supported or not, going anywhere from a reduction in fps to +90%. But it appears as though a low end intel + R9 260x is a much better proposition overall, unless you're going super cheap without a discrete graphics card
And, as above, the 260x doesn't x-fire with the kaveri
(A)bsolute (M)ediocre (D)evices
Will this allow 1080 res, medium to high game settings
I play mainly racing games, call of duty fifa and battlefield sometimes
That, s brill still have some dosh left over, there are a few R9 270x with 4096mb are they worth the extra £20. Also would you recommend a board from Asus as I know my way around them. Appreciate the help thanks
Ive got the asus crosshair for my fx8350 which I love, very easy to overclock on
nah the 4gb is not worth it at 1080p.. unless its 1440p and at 1440p you wont be using a 270x in the least!
