F1 Testing 2014: Week 3 Bahrain
No way you can blame this all on Renault, newly designed a car without the needed cooling. Even if the Renault engine worked well, it would almost certainly overheat. Just look at rbr side pods and ducts compared to any other car this season. Both Renault and rbr have stuffed up.
Yes the car will almost certainly be fast, but Mercedes would be even faster if they made their side pods smaller and overheated after a few laps.
Renault balled up on engine and rbr underestimated heat of the new PU.
And agreed, there is nothing called luck. Its being good at your job or bad. This year both Renault and RBR have made bad choices. The question is how bad is this going to be. I don't think its going to be the catastrophe most people think.
Oh definitely not, Helmut Marko has been quoted as saying that RBR are 2 months behind.
Whilst I like the Mercedes outfit and its two drivers, I wouldn't want any team to totally dominate throughout.
+1
E: that article is quite worrying if the 1.5 seconds / two lap rumours are true. As much as I want to see LH get his second WDC, I would prefer it if it wasn't a Vettel-esque cakewalk.
I think the fact that only one of the four Renault teams has seemingly had adequate cooling out of the box (Caterham) suggests to me that Renault slightly under-estimated the cooling requirements of their power unit.
It's all too easy to blame Newey because he's done it once before and has a history of uncompromising design, but do the chief designers of Toro Rosso and Lotus have the same restrictive mentalities, while of the other teams seemingly all bar Sauber have sufficiently gauged the requirements correctly? Highly unlikely.
On the other hand I dont think its any coincidence that the teams with a different design philosopher of rather than don't compromise aero, but rather incorporate the tech and have been doing it aggressively since KERS was introduced, are the ones looking in the strongest shape.
I think I read somewhere that Mercedes were quite strict on things like engine cooling, orientation, etc. Step outside of their packaging spec, and you're on your own.
I think Renault allowed more freedom with the packaging, and it's bitten both Renault and RBR. They've both built something that's too close to the limit, and can't make them work together.
On the other hand I dont think its any coincidence that the teams with a different design philosopher of rather than dint compromise aero, but rather incorporate the tech and have been doing it aggressively since Lear was introduced, are the ones looking in the strongest shape.
I'm sure if people could understand what you type you would get more responses.
i know many people are looking forward to the season but i think that will wear off soon if merc do indeed have athis huge advantage
i would say its 50:50 whether they do or they dont
Merc seem to have the engine advantage, they are a works team..thats 2 nice compounding factotrs
Merc may be quite a bit ahead in pace, but the threat of reliability issues will keep things interesting IMO.
I can't believe how soon the start of the season is, I can't wait. All of the rule changes have certainly led to interesting reading so far and the racing hasn't even started yet!
not if they are the most reliable! :p
2nd place in WCC could be very interesting
Remember Merc had two gear box failures in the last test both after 89 laps.
So Aus may well be a cake walk for them, but the 2nd race is where it starts to get interesting.
(I think the componants have to be used in consistant races but I could be imagining that)
It depends whether those gear boxes were new on the day they failed or the same boxes had been used since Jerez.
If it's the latter (however unlikely) then those boxes lasted ~2,000Km before they failed.
Assuming practice and quali equal the same distance as the race itself, you're looking at three full race weekends before those boxes failed.
because in testing they are going to change out a major componant for one already well used, seems highly unlikely
At least one of them lasted just over 1 GP (which is usually 60 - 70 laps plus another 9 - 10 at least for quali)
While not impossible - its highly unlikely the BBC would have said that either / both only lasted 89 laps when it was in fact a well used one from previous tests.
I think the McLaren and Williams PU failures were down to 'well used' units. I guess this must give them a base understanding about which part(s) are likely to fail first.
They actually will, knowing how and when parts fail is pretty crucial to being able to see it coming next time.
They'd want to compare two engines maybe one old one new, to check power loss, lap speed, efficiency. They'd want to know if say an engine fails is it worth taking the hit and taking a new gearbox or does an old gearbox work fine with it.
More to the point, where does it say that Merc had a gearbox failure after 89 laps or that both lasted only 89 laps? As far as I can tell, it's simply not what happened.
All I can see is that the gearbox failed on day 2 after 89 laps, it could have gone for the same 6 days the engine did before that. Then then ran 103 laps or something on the third day, and found a problem before the first test started on day 4. So the second gearbox seemed at least to do 103 laps. They also afaik only said they found a problem which caused other problems in the car, I haven't seen them specifically say it failed. They are new cars, the same way they take hours to replace an engine where in 3 months it will take them probably less than half the time, bits get fitted incorrectly at the start of a season in testing in a rush, that is no surprise either.
So one gearbox failed after absolutely no idea how many miles, only after 89 laps ON THE DAY, which isn't relevant as that gearbox could have been 100 or 400 laps old for all we know. The second one we presume failed, but could have been any problem, and we really don't know much about it.
The only thing I can tell from looking up various info, is neither failed specifically after 89 laps, and I have no idea in the slightest where that info came from.
Yet the W05 is by no means without flaws. Just consider the litany of problems the team endured throughout the third and final test of the winter: persistent overheating on Day One when the team had to abandon their attempt to run a Melbourne race specification, a spin for Hamilton and a gearbox failure on Day Two, an eight-hour overnight engine change that curtailed their Day Three running, and nearly four hours of track time lost on Day Four due to another gearbox complication. If any of those problems are repeated in Australia, their speed advantage will count for naught.
From skysports, so overheating isn't exclusive to Renault, as I've pointed out before, Merc and Ferrari brought extended cooling versions of their cars for hotter climates. Red Bull just seem to be ignoring this idea completely.
Secondly, the second gearbox problem isn't described as a failure, and came after a new engine was put in. We don't know what kind of failure it was, and the 89 laps thing is seemingly made up from somewhere.
post on another forum
mclaren_mircea wrote:Review of the Mercedes problems
1-9: FW failure
2-9: Gearbox issue
3-9: Electric issues
4-9: Brake by wire
5-9 : "small problems" (they didn't tell the nature of it)
6-9: Hydraulic failure
7-9 : Gearbox
8-9: Engine issues
9-9 - Gearbox + oil leak
If you say that that is normal during the testing time, that 90% of your running days you report a technical problem, or that you saw this situation on a Mercedes car in the last year's winter testing, or in actuality if that is similar with other team's problems (except the Renault powered cars), than I can say that you can continue to ignore the reality :(
If you say this year winter testing is comparable with past years winter testing and you continue ignoring these are new cars that need to be tested and need to find the weak points, then I can say that you can continue to ignore the reality :P :mrgreen:
That list means nothing by itself. How do you know those parts break before they were expected to break? How do you know they didn´t have 120% of their expected lifespam?
You know they´ve break, but you don´t know if the team was pushing the limits to see what was the first part breaking, or how many mileage had done those parts that broke
A list of problems, someone's rather silly take on it, and a great response. Merc have confirmed(over all the tests) several problems, but we have no idea why the failures of if they tried to induce the failure to some degree. As important as having a working car, is knowing when you won't have a working car soon. Take a 10 place grid penalty for a new gearbox(not sure what it is this year actually) or engine or fail midway through a race, where you might not win but might get say 4th or something starting from the back. That is a key decision, and knowing roughly how the gearbox starts to give feedback as it approaches failure, or any other part, and knowing when to replace it will be crucial in a season of unreliability.
Ferrari have had a gearbox failure, and I'd bet on most teams having some issues with most parts of the car.
