Titanfall (Respawn Entertainment's new IP)
Seriously need to upgrade my broadband as well :o
I just received an email in spanish (got it in mexico). I think it´s telling me that I can preload it now, but it doesnt look like I can right no, my Origin still has 10th for preload :/
The email does indeed tell you that it's ready for pre-load, I got the same email about an hour ago, but the Origin client detects your UK IP and obviously won't allow you to start pre-load yet. Close it, connect your VPN, start origin again and the pre-load option appears.
See my screenshot just above if in doubt.
Titanfall for PC through Mexican Origin.
Use Hola for Chrome, or another free VPN if you want.
https://chrome.google.com/webstore/...ternet/gkojfkhlekighikafcpjkiklfbnlmeio?hl=en
1. Go to www.origin.com and turn on Hola and choose Mexican (Will be in Spanish but use Google translate if needed)
2. Put Titanfall in the basket (Standard will be 499 mexican dollars. Digital Deluxe will be $599 MXN)
3. Open shopping basket and click proceed from lower right corner
4. Disconnect from your proxy just before logging in to Origin.
5.Log into your origin account (and change page language to English if needed)
9. Buy it like normal, (If using Paypal, just stuck in a random Mexican address)
10. Order will complete as normal and you will get confirmation email and Titanfall now in your origin account!
It's appearing in my Origin games list so I'm assuming it has worked. Thanks. :D
Anyone finished pre-loading yet?
Mines sat at 99% now for a while. Maybe it's actually extracting files?!?
EDIT - Now changed to installing. Must have been running a CRC check or validating the download or something.
My VPN messed up and now whenever I try to connect the network connection says 'network cable unglugged' - Anyone got any ideas?
That's what I did initially, just stopped the VPN again now and the same thing, says it lost connection to DL server and then wont resume.
Unlucky mate.
I literally started the download with the VPN and as soon as it was downloading I disconnected it and it did the rest on my connection.
It's now installing -
Guess it takes too long for the net connection to come back when the VPN closes so it realises there is an issue. oh well, going again now and will see what happens when my 20 mins free runs out!
I'm not that bothered about preloading/playing early, I have plenty to be getting through before the 14th. Just happy with the discount. :D
Snagged it from Mexico as well, bargain for the Digi Deluxe version.
Not going to bother pre-loading yet as i'm waiting on my new SSD to arrive to install it on first :D
