Preloading it now, 50GB DL![]()
Thought it was a 21Gb download and 48Gb once installed. Where you getting 50GB from?
Mine is saying preload starts on the 10th, did you use a vpn to unlock it?
I just received an email in spanish (got it in mexico). I think it´s telling me that I can preload it now, but it doesnt look like I can right no, my Origin still has 10th for preload :/
Try again it does go through! Worth it for the saving.
Titanfall for PC through Mexican Origin.
Use Hola for Chrome, or another free VPN if you want.
https://chrome.google.com/webstore/...ternet/gkojfkhlekighikafcpjkiklfbnlmeio?hl=en
1. Go to www.origin.com and turn on Hola and choose Mexican (Will be in Spanish but use Google translate if needed)
2. Put Titanfall in the basket (Standard will be 499 mexican dollars. Digital Deluxe will be $599 MXN)
3. Open shopping basket and click proceed from lower right corner
4. Disconnect from your proxy just before logging in to Origin.
5.Log into your origin account (and change page language to English if needed)
9. Buy it like normal, (If using Paypal, just stuck in a random Mexican address)
10. Order will complete as normal and you will get confirmation email and Titanfall now in your origin account!
At what point can I close the VPN? I had about 7mb and closed it, then the proload stopped and wouldnt restart
I closed it about 10 seconds after it started and it went ok for me.
That's what I did initially, just stopped the VPN again now and the same thing, says it lost connection to DL server and then wont resume.
