***The Vapers Lounge***
Status
Not open for further replies.
Asda's Little Angels range 100% Pure Cotton Pleat. 2x 300g Bags for £ 2.50.
It's what I send with my MicroCoiling kits and use it myself. Yet to have any negative feedback on it.
As for tutorials: AndyW's Guide to MicroCoiling the Kayfun Lite on YouTube is about as thorough and comprehensive as you'll get.
I've just re-wicked it using less cotton and it tastes better but it still has a funny taste.
The cotton i've got is this http://www.wilko.com/bath-toiletrie...cotton&VBMTC=39efded9734189788324f3876f9b64cb
Can anyone recommend any.
If its the pads you are using, make sure its cotton from the middle (i.e. separate the two "harder" sides). I think the outer edges are treated with something to make them stiffen slightly, which may account for the taste.
Or, as suggested, pick up the Asda cotton wool. No issues at all with that.
Does cotton have a breaking in time, i ask because this banana split is tasting really good now, much better than my nautilus, i can taste the banana a lot more whereas i get mostly vanilla in the nautilus.
Also the TH from these micro coils is really stong, i might need to drop my nic level, i'm using 18mg at the mo.
My KFL takes a bit of breaking in with new cotton to get the best. I run a 1.6ohm microcoil with cotton and keep it at 4v constantly. Easy peasy to set up and gives a great and consistent vape.
I do change the cotton after each tank as I do find with triphammer juice it will gunk pretty quickly.
Love it :cool:
I'm stopping 18mg, way too peppery for me at back of throat in a dripper, and affects flavour. I only do 12mg now, it's much better and still get good nic hit, I just have to vape a bit more. :p
Will get round to building my new KFL+ later, think I'll do silica instead of cotton wool.
Meanwhile, after 5 weeks, slowtech finally delivered one of my 3 orders, a bunch of different coloured hybrid drip tips. Don't know if drip tips affect flavour but I seem to get more flavour with this one than my all SS shorter one. I love the look of it.
Ok so I'm a bit confused. I have just ordered These and have just noticed they don't say IMR are these ok to use in the SVD I just ordered or should I email him and ask home to swap them.
They will be fine, i have used Torchy's batteries in my Vamo, Evic and a mech mod
Guys, spec me some more Vaping King juices please that you've tried, they have become my go to vendor since they're the only ones so far whose juices work for me (only tried apple pie and monkey jizz).
I'm ordering kings custard, and chocolate fudge brownie has been recommended too so am ordering that.
So MDV 666, Strawberry Crunch and Vamp Kiss. I can't buy them all but I could buy some. Are they all awesome, and which has the nicer biscuit taste out of the Dodger and the Crunch?
edit: Bah, no one here to save me money. Bought them all :D Messaged Billy and asked for a 1ml sample of rhubarb and custard. Got discount with VK10.
Received 2.43 loyalty points now, and after 5 points I can convert them to £5, so, a free bottle of juice.
Not so much a breaking in time, but the cotton does seem to take a little while to fully saturate with juice. If I vape my dripper with fresh cotton and vape it too soon after priming, I get a little burnt flavour.
I've found priming the cotton when freshly rewicked and putting a few drops in the juice well, then waiting 5 minutes and slowly adding a few more drops (until the cotton won't hold any more and it starts to run into the well), appears to give the best results.
Bit of a faff, but this is Vaping at its best...
I like the look of that drip tip :) Can you tell me what FT SKU number that is please?
Actually ive been thinking the same for a few days, for weeks ive been struggling with my kayfun getting it to taste right, dawned on me a few days back it could be the TH making it seem off and wrong - only issue for me is my all day vape is RY4 Nutzilla by flavourart and they dont do a 12mg only a 9mg which i feel might be too low :(
Tried mixing my own a while back, and couldnt get on with it at all, never tasted right at all.
What's people's opinions on a decent tank? I've got a aerotank that burns through heads every 2 days and a iclear30 which lasts ages but hardly any taste?
Starting to wind me up big time!
What about mixing 10ml of 18mg and 10ml of 9mg and you should end up with 20ml of about 13.5mg
Went and got myself some of this earlier and its tastes some much better, no more funky taste i was getting from the bag of wilkos organic cotton.
Thanks redmogg.
I agree, Thanks RedMogg, I went and got some of this and its stacks better than the Sainsburys stuff I was using before.
Status
