1420 core clock, i wish any of AMDs AIBs sold cherrypicked cards
Extreme makes better use of the 290s bandwidth
1420 core clock, i wish any of AMDs AIBs sold cherrypicked cards![]()
I think that he's just envious![]()
Smaller increases now, still an increase!
10460
http://www.3dmark.com/3dm/2638639
1190 core
1750 mem
+200mv core
+50 power limit
Got an improved score but can't submit due to the time measurement data,http://www.3dmark.com/fs/1713746
Is there any way on win 8 to delay a driver crash?? I never get artifacts, it just lets go which is really annoying.
Its windows timeout, detection, recovery if it helps.
If you forward it to Futuremark they might submit it mate. I got it all the time last week but it seems to be ok now with same settings. Only thing thats changed is the Sysinfo update. (latest WHQLS).
Also, I hate your cards.
If 3Dmark returns "TIME MEASUREMENT DATA NOT AVAILABLE", I will not be allowing the scores to be entered.
He won't allow the entry with that showing.
http://www.3dmark.com/compare/fs/1713746/fs/1732258
Reference Rape![]()
@ Walder, I have a higher score entered for you as well![]()
The higher score you had for me was on my reference 290X, I am now on a Tri-X 290 but have just beaten my best 290X score anyway! I think both results should stay in there though as they are on different cards?
Tbh it won't alter my position on the board which is why I havn't done anything about it.
More interested in why I get driver crashes, and yeah I know it's at its limits but when runnng firetrike it's buttery smooth and no artifacting and then the box pops up telling me the driver has recovered. So by dissabling the TDR limit I'm hoping it may go a little further. I want to be the one that decides it's had enough, not windows. Can't test till after work and by which point the mrs will have the heating on!! Boooo!!
Core clock / more volts for driver stopped and recovered. Say at 1340mhz I won't get artifacts if the cards are kept cool enough but it will just CTD and driver will stop responding. That's what it is for me anywho. VRAM instability = hard lock for me.
Only difference being, you can add a few extra volts and I can't![]()
40c for me is a turning point as well albeit at lower clocks and volts. They love to be kept under that! My limits on my best card are 1316/1975 @ 1.212v 35c. I can manage 1340mhz core but need even lower temps. These cards love the cold
