Caporegime
- 13 May 2003
- Warwickshire
Woo, another shaving argument!
But hopefully in amongst the "man the **** up" and "I am a bigger man than you because I used a Merkur" there will be some actual answers to the question: is the ProGlide better than the Mach 3, specifically the M3 Power?
I tried the normal Fusion a while ago and didn't get on with it. It irritated my skin and didn't cut as closely as my Mach 3, so I went back to my trusty servant: M3 Power blades. However I was wondering if the ProGlide is significantly better than the normal Fusion?
I should also mention that I dislike shaving and my only wish is for it to be as quick, easy and smooth as possible. I typically shave in a hot steamy shower in front of a small mirror attached to the tiles at face height, every morning apart from Sunday, when I give my face a rest. I don't care much about blade cost either.
Cheers.
Cheers.
