Reverse failed on the auto box. To have the box rebuilt is ~£1500 including fitting, fluids and filter.
Car with fault is worth £1000 at most.
Car with working gearbox is worth around £2000.
I'm confident it's worth much more in bits than whole, although appreciate it takes some time and effort to break it up.
The main motivator behind breaking was I want to keep a few bits for my e39 Touring. For instance, I fitted 4 x Goodyear F1A2s and BMW OEM discs and pads ~500 miles before the box failed. These will be used on the Touring in due course. There are also other parts I've replaced on the Saloon which I'll transfer over to the Touring as preventative maintenance (DISA Valve, Refurbished VANOS, recent CCV system etc). Plus any other parts or trim that are in better condition on the Saloon than the Touring.
It does feel a bit wrong braking it as it's in such good nick.
so I've had to buy an N95 just for that!
