Get the MSI 270X instead, better card over the toxic.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-226-MS
sorry for all the questions guys this is my C:\ drive (win 7 sp1 ultimate 64bit)..Seagate Barracuda 7200.12 ST3160318AS 160GB 7200 RPM 8MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive ,and my D:\Drive...Seagate Barracuda 7200.12 ST3500410AS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5"...I dont want to replace these drives(not yet anyway)..will these drives connect flawlessly to the above named Motherboards..Thank you for any advice
Thank you Idleman for your advice..Thanks to all others as well who have helped with my questions...Cheers guys .
..does Anybody have any tips as to what to uninstall from my system with regards to me keeping my Hard Drives and changing from My Phenom 2 955 to a Intel I5? One post quotes this "Make sure you definitely remove boot disk interface (IDE ATA/ATAPI
..ThanksAs you are changing pretty much every component I would just do a fresh reinstall of Windows for sure. Why are you trying to avoid a fresh reinstall?
Im not Walderx i just wanted the easiest option i suppose..What will happen to my Games\mods etc installed on the C:\drive will they be ok? i know to back up important files\photos etc..any advice? cheers
I just think you are asking for trouble trying to keep your existing Windows installation on totally brand.new hardware. I would expect bluescreens galore!
BTW you won't need 4gb VRAM with a 270X, there's not enough beef there with the 270X to utilise the whole 4gb
recommend me a board if you can guys..im torn between 3 boards...
1.Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £107.99
2.MSI Z87-G45 Gaming Series Intel Z87 (Socket 1150) DDR3 ATX Motherboard £106.99
3.Gigabyte Z87-HD3 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £82.99
Hoping to pick up in store and build today guys..Ive had Two gigabyte boards in the past..zero problems i shall NOT be using xfire if anyone can give me recommendations id be most grateful..Thank you..Ps its to go with a Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor,and a MSI Radeon R9 270X Gaming Edition OC 2048MB GDDR5 PCI-Express Graphics Card ,and TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit ..Thanks guys
