Hotswap Bays
17 Nov 2013
United Kingdom
As above does hot swap bays actually slow down your SSD.
I have seen some results before where the read/write was greatly reduced because of using hot swap bays.
I currently use one in my 900D but have never tested this as of yet
I'm running 2 icyboxes for my storage drives. tbh there's no drives out there yet that can saturate a SATA2 bus (3GB/s). Any caddy out there will support SATA2, especially any that allow the SATA data cable to connect directly to the hdd. Experience talking.
the 900d hot swap bays? no they are fine there is nothing wrong with them
Yeah I have had a few cases, the Zalman I had used to slow my ssd speeds down.
I haven't checked the 900D bays but wasn't sure if it was a general thing
Thanks
There are loads of drives that exceed Sata 2. Sata 2 is 3Gb/s which is roughly 375MB/s. Plenty of SSD's have 500MB/s + Read / Write speeds.
