Looking for advice on electric bicycles...
Thought (read presumed) it came from the lithium battery that you charged up.
Well some quick googling suggests otherwise that they can go for miles before needing a re-charge.
Learn something new every day.
You will still have to pedal an e-bike..
You don't, they have a throttle.
Where do you think the power comes from :)?
Get a segway.
The huge battery... What exactly do you think an e-bike is? :confused: Segways are slow and quite dangerous compared to an e-bike, they can only go over even terrain too.
If you can't pedal much, then I would recommend getting a bike that has a crank drive motor and not a hub one, as hub motors don't put out much torque so would struggle going up hills by themselves. Also just so you're aware, using the throttle is technically illegal, but that's not ever going to be an issue in reality.
The huge battery... What exactly do you think an e-bike is? :confused: Segways are slow and quite dangerous compared to an e-bike, they can only go over flat terrain too.
Thanks for that, I know nothing about them, just thought the idea of them sounded like a good way of me still being able to get out in a bike. The idea was for more sort of off road type areas, liked woodland cycle areas, so fairly flat, but I'm guessing it's best to go for the crank drive anyway?
