- 20 Mar 2007
- Norwich
Itronics ITB-100HD
Thanks a lot, much appreciated!
Itronics ITB-100HD
CV joints are a weak spot on Corsa D's. Had one knock when turning at low speeds.
I think I'd rather my car go up in flames than see it stripped for parts.
Repairable or not?
Parking sensors failed (2 as it turns out( while reversing into the driveway and I bumped one of the bits of the house. I usually wait for the long beep to denote 30cm from the corner and edge back a bit more but on that occasion the 2 sensors failed at that moment and as is the case with these sensors, if one goes they all go bonkers even if they're not faulty.
Changed the Carbon trim on my E46 to Silver trim and fitted new foglights after 1 got smashed on the motorway!
