Caporegime
- 13 May 2003
- Warwickshire
My tip for shaving sticks like the Arko and Palmolive ones is to unwrap them and press them into the bottom of a suitable container. This allows you to lather up straight off them with your brush and a little hot water.
Nice tip, I'll give that a go tomorrow, thanks! I suppose the good thing about applying it straight onto your face with a stick, is that it presses the soap into your beard as it's quite stiff?
cost me 18 quid so the quality might be questionable! We shall see midweek next week hopefully!
