3rd Day off the analogues with my new iTaste VV and Aerotank. So far so good.
Well done
I started on 24mg juice, then 18, now on 12mg no problems.... gonna stick with 12 for a while as actually enjoy vaping
Reading these posts is confusing and it seems a like what you guys are doing involves a lot of hassle. Are there no good off the shelf alternatives that I could just buy then just change the tip with new nicotine free flavoured juice?
Sure, there are plenty of devices like this. Look at some of the eGo systems.
The thing is, vaping, like anything; has extremes. People in this thread tend to be the modders who want to get the best flavour etc and are prepared to put the work in.
It's like cars, or computers. You can buy a nice new car or computer that will do a lot of people just fine, but for many people it's not enough.
Trustfire = in the bin
Buy some AW or Efest batteries.
You want IMR safe chemistry batteries.
The Panasonics he mentioned are just fine for use in a Vamo, and pack a good capacity.
No need for IMRs in a mod with protection circuitry.
Probably but I would prefer to be as safe as possible with batteries and my face. Don't really like batteries in the face tbh.
Hey all! Looking to upgrade by vaper, currently using http://www.myshishapen.co.uk/products/rechargeable-refillable-electronic-shisha-pen
Have no real problems with it, only when changing flavours the clearomizer will still taste of old flavour for a while, I know simple solution is to buy clearomizer for each flavour.
What do people suggest for an upgrade on my vaper? Nothing to fancy, not sure if variable voltage is my thing.
Hmm well sort of agree but personally I would stick with the safe chemistry batteries at all times with any mod etc. Sure it will be fine whatever he does, but I would chuck the trustfire POS tbh, for example![]()
Do these flavours have nicoteen in them? You're still inhaling nicoteen and not the other ***t that goes in ciggies? I'm now a non smoker - gave up using champix. Just curious to see if those that gave up ciggies are still addicted to the nicoteen, if there is such in the flavours![]()
Shamless self bump xD
Right I've managed to wait since thursday night until now to try my home-made juice and it's not too bad, colour wise I believe it definitely needs to steep quite a while longer but taste seems good initially. Might mix up a few varying batches to compare.
