I've posted these gpu usage pics before in a couple of threads, this was fc3
using a 7950 clocked 1050core-1600 memory, usually its 1175-1600. In fc3 with the stock fx8 it really does stutter badly and feels like something is wrong. At 4.8ghz there's still a bit of slowdown but it's much smoother. I've tested a few games since then and the results are interesting. Bf3 multiplayer although shows the fx8 really holding the gpu usage back, (70%) at 3.8ghz and 4.8ghz , the game runs smoothly and without a fps counter you wouldn't know the gpu was being held back. The 2600k even at stock 3.5ghz holds higher min and average fps but gpu usage does drop down to 80-85%, clock the 2600k though and it holds 95-98% gpu usage. If you want to see a bottleneck, then try running truck simulator 2 on any cpu lol.
fx8 3.8ghz
fx8 4.8ghz
2600k ht on stock 3.5ghz
2600k ht on 4.8ghz
fx8 3.8ghz
