first time watercooling advice
19 Dec 2013
Penrith, Cumbria
hi guys,
I'm planning on building my first loop (cpu only) and I don't really know what to get. my budget would be £170 maximum (less would be way better though) and i've had a look at these kits:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-265-XS&groupid=962&catid=1532
http://www.overclockers.co.uk/showproduct.php?prodid=WC-020-TL&groupid=962&catid=1532
http://www.overclockers.co.uk/showproduct.php?prodid=WC-234-XS&groupid=962&catid=1532
what do you guys think? I've got a fx8350 that's currently at 4.4ghz but anything higher (even at stock voltage) gets the temperatures too high.
thanks
Jimmy
edit: or would i be better off just getting a better air cooler? my case is a nzxt phantom enthusiat and i don't have a side window
I'm thinking of putting my gpu underwater as well when I change my case so I'd like to reuse some parts. Would the pump in that kit be enough?
The pump is enough but not great and can be noisy. Barbs are also something i would never recommend over other kind of fittings.
An extra score and you can net the following set up with the 4.0 pump and some fans:
YOUR BASKET
1 x EK Water Blocks EK-Supremacy Clean CSQ - Acetal £49.99
1 x EK Water Blocks EK-CoolStream PE 240 (Dual) £39.95
1 x EK DCP 2.2 Pump (12v) £29.99
1 x Alphacool Reservoir Repack-Cooling Slot-In Black £21.98
1 x Primochill Primoflex Advanced Tubing 13/10 - Clear £5.99
8 x EK Water Blocks EK-CSQ Fitting 10/13mm G1/4 - Black £2.99 (£23.92)
Total : £171.80 (includes shipping : ).
The pump in the kit is far from a D5. It is noisy and is only really strong enough for small expansions. Sports a similar flow to the 4.0 but with less than half the head pressure and far less flow than a D5 with considerably less pressure.
Well, Seems this is a misunderstanding,
maybe on my part, maybe on yours.
I was assuming (My mistake to assume) that OP's question was referring to 'MarioGameTV's suggestion. as that was the last 'kit' talked about, That kit said "d5 variant" which is not what I'd have assumed it was
I saw this res in the Kit:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-186-XS&groupid=962&catid=2141
And mistook it for:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-140-XS&groupid=962&catid=2141
The kit in the pictures show a 750 x20 which is not a D5.
The title also lists the pump as this pump:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-186-XS&groupid=962&catid=2141&subcat=2142
Which matches the picture. The V4 is not a D5. The description is likely wrong as the D5 pump res combo looks similar but is this:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-140-XS&groupid=962&catid=2141&subcat=2142
Which at full price costs practically the same as the kit.
Kit Contents:
- RayStorm CPU Waterblock
- X2O 750 Bayres/Pump (Black) V4
- EX240 Dual Radiator
Thanks for all your replies guys. I only saw the barbs once I posted (oops) and I refuse to use them. I'll shop around and see if I can find a second hand pump anywhere.
Thanks again and keep the suggestion coming if there's anything else I should know.
Ok cheers. I think I've just managed to sell my 660 for £70 so I'll have extra money for a good pump (D5 more than likely).
I don't know yet where I'll attach the res pump combo but I'll see
