The Battlefield 4 Thread ~ Server details in opening post ~
Status
Not open for further replies.
Both the XB1 and PS4 are completely different architecture to PC's.
These two worlds are coming closer together with mantle however. Who would have guessed that it would be PC's mimicking consoles and not the other way round.
Quality Josh! Remember you saying about the rubber banding before and that tank was from last night!
Think I might start recording some stuff just to mess about with.
If you can get good clips it is great fun, I record loads but I'd say 90% never see's the light of day.
Need to record a full round and edit it down to about 10mins, [OcUK] Squad up style!
Just been practising on test range with the 20mm in stealth jet and have to say I like it a lot! :D Think it's because my accuracy with jets is better now as opposed to 2-3 weeks ago :p
Fun destroying stuff from 3P view as well :D
Think that's the plan, got Shadowplay so would that be the easiest way of doing it with minimal overhead? Never tried capturing gameplay and only used FRAPS for FPS in game before :p
Seems like my tank shots are not registering against helis now, couple of weeks ago it was fairly rare for them to not register but now it's every other shot :(
Nexus has had similar
Yup shadowplay is simple, set it up to record and save files then just press
ALT+F10 and is saves the last between 1-5mins.
Or set it too record ALT+F9 to do the whole round.
Cheers, just jumped on test range with it, it is rather simple and good quality, impressed
Will let it record whole round, I know I will forget to hit ALT + F10 when something decent happens!
Yep shadowplay is the way to go.
When it comes to editing I would avoid Lightworks, it screws up the audio and makes it go out of sync.
You and your SYMple friends can go shove an IGLA up your ass. :D
Windows Movie Maker, it's free and simple to use. I have Sony Vegas Pro and it's just overly complicated to use for a casual little montage.
Status
