Good, F1 doesn't need cheats.
Best kick out pretty much everyone else too, then.
I've missed Ronspeak™.
As my favourite team boss is back...
"The new F1 is like the Tortoise and the Hare - we want to be the hare."
Grow up horner.
Why?
The FIA never stipulated that the fuel flow mass readings must be taken from the homolgated sensor, that needs clearing up and that is the point that Redull/Horner will want to get clarity on. According to Redbull / Horner, from their own measurements they are not in breach so why is he being childish?
The FIA left the door open, lets all blame the team that chose to push the limits and call them childish, rather than bad mouth the historically sloppy governing body......![]()
Why?
It's not hard...really..
FIA...turn your sensor up\down
rb..NO
rb..NO
You have been warned now turn your sensor up\down
rb..NO
Your OUT....
rb but our sensor is better then yours. And just because ALL THE OTHER TEAMS DID AS YOU ASK we won't.
Please leave F1 rb or don't bring more shame to it.
Thats suspect to start with but even without that the FIA warned them numerous times after telling all teams that they HAD to comply and RBR chose to ignore them
Yes on numerous occasions RBR as a team have come across very childish over this
snip.
Red Bull team boss Christian Horner thinks that as long as it was within the maximum fuel flow rate as specified in article 5.1.4 of the F1 technical regulations, then there are no grounds for it to have been thrown out.
Speaking exclusively to AUTOSPORT, Horner said: "Technical directives are not of regulatory value.
"They are the opinion of the technical delegate - as was made clear in the Pirelli case [the Mercedes secret test], which clearly stated that opinions of Charlie are not regulatory.
"It [them being opinions] is even stated on the bottom of the directives now, that these do not have a regulatory value.
"Our position is as it was in the race: that we believe, and we believe we will be able to demonstrate in the court of appeal, that we fully complied with the technical regulations - 5.1.4 - to be explicitly clear."
All that means nothing as rb are not arguing about the sensor but the words in the FIA rule.
"FIA’s Technical Regulations with Article 5.1.4 stating ‘Fuel mass flow must not exceed 100kg/h’. However does not say that this reading has to come from the FIA’s sensor"
Horner is just laughable. And Horner thinks he will run F1 when Bernie stops...not a chance...ever.
http://www.autosport.com/news/report.php/id/113091
I didn't expect them to take this approach to it, to be honest, but I suppose it's better than just saying "we're right, you're wrong", at least.![]()
