You can only fit 2 x 140mm fans in the roof though FYI - my X60 is 2 x 140mm and it fills up the top almost (sorry about bad light - my White LED's rape my iPhone camera lens):
Has anyone tried static pressure fans like SP 120's in the case front to push air in?
Case looks great all blends well, sorry for off topic what's the far right monitor?
I managed to solve my heating issues by putting two TY-147s in the front. The most air gets pushed where the two fans meet, and thats pointing directly at my GPU, lowering temps by 5-10C. I'm using the x3 120mm as top intakes, but they only come on when my system temp gets above 40C, my GPU gets above 60C or any of my CPU cores get above 55C. Yay speedfan
http://imgur.com/jTvlUD8
Good work on that, how do you get the top fans to kick in at a certain temp, just about to install my top 120mm's and could perhaps do with this myself.
Loving this news! So perhaps just ill-equipped fans is the problem!
*and OCUK are out of stock*
I'm not good with fans, any close alternatives?
Really tempted by the Noctua NF-A15 : 150mm fan in a 140mm socket.... I would simply MAKE these fit, the static air pressure / dBA seems like it would sort it out
*ordered 2 of these fans for delivery Friday*
Personally I would keep the Positive Pressure that is caused by having more intake fans than exhaust fans, it helps to keep the air being forced out all the vent holes it can (mainly in our case the vents around the graphics cards)
