MSI Afterburner 3.0.0 Beta 19(2014-3-27)
Just seen your vid on Twitter Matt and seen the throttling you are getting :( One question, Why does Lara's hair flicker like that? Looks horrendous.
Dunno, does not normally do that and never happens in game. PG tips (i think it was him - either way someone here with a 780 SLI setup) said it happens to him sometimes as well so sounds like a game issue rather than a driver issue. It will never get fixed now either as they ain't updated the game for ages.
Dunno, does not normally do that. PG tips says it happens to him sometimes as well so sounds like a game issue rather than a driver issue.
Fair enough. Never seen it myself except when it was first released and I was playing in triple screens. Since Square/Enix patched it, it has been perfect. Maybe a 14.3 bug?
Happens to SLI as well it seems.
Its a game issue affecting multi cards only. Luckily its pretty rare but does happen sometimes.
whats the gpu usage like on 290s now?
Do you mean how it displays in afterburner? If so theres an alternative detection method available (see my earlier post on the previous page) which takes a different reading and its much more consistent so yes, perfect.
ok just updated to beta 19 and it now sets the Vcore on my msi r9290 from +13 up to +25 on stock (977/1250)? is anyone with the same card getting the same thing? just on beta 18 i was using +19 for 1130/1450. +25 on stock just seams a bit much.
I can let you know tomorrow I have two theses cards.
edit
Nope mine was 13+
edit
Nope mine was 13+
is it still +13 when you click on reset in afterburner? just when i click it , it gos for +13 to +25? just stock clocks its now using 1.234v.
one more thing to ask. dose anyone know if you can unlock the memory voltage (Mv) for the msi R9290? just its blocked out in afterburner still?
I checked extend official overclocking limits, and now i can slide the gpu voltage to +200mV :)
If I click reset it does in deed go to +25
Man these forums a pain in butt on phone.
Anyone else seeing throttling between using this latest afterburner and latest beta drivers?
Clocks used to be rock solid on 14.2 and previous afterburner. Now seeing quite a bit of clock fluctuation.
Tried both bios position. Not had much time to look into it with prepping for interview
