Not played since it came out
Ruined by those pesky Titans!! .but, like i said ^^ ruined by Titans.
It is called Titanfall for a reason.
Quite surprised the game is capped at 60 fps still but it doesn't spoil the gameplay at all.
My thoughts as well
I wasted £44 on Titanfall, played for 3 hours and uninstalled.
 You won't scratch the surface of the movement system in 3 hours, let alone get an idea of how the game plays. Best multiplayer PC fps in quite a while btw - after years of CoD and BF iterations it's nice to have something a bit speedy that needs reactions, aiming and movement skills!*snip*
)Been playing Titanfall all day and decided to look at the usage I was getting. Sits at 60 fps with full settings but check out the VRAM usage
3580mb at 1080P is a lot. What usage do you get in this and what GPU are you using?
I think that might only be with Crossfire. Not 100% though.If you using a pair of 3GB cards in SLI your actually only using 1.8GB.
Wrong. SLI reports the actual usage not the usage multiplied by two like in crossfire.
