This is a very quick update!
first of all, A massive thanks to
https://www.bellystockings.com
  for sending me a LOAD of material!
as most of you guessed correctly, i will be making some nice fan filters with them.
As im now running out of time in getting this build into a usuable state though, i am just going to have to use tape to get it in place, i have a way better idea, so this WILL be updated in the near future.
so, first, here is how much they sent (around 2.5M x 2.5M
Its actually a really good material, its stretchy, easy to work with (if you make a little mistake whilst cutting, you can just stretch it a little bit more to get the desired shape
and im hoping it will do an awesome job at keeping the unwanted dust out of the case.
also, its cheap!!!! (from their website, its around £9 per meter, which is plenty do do most cases!
Ive been informed that they do do some finer material as well, so if you want to make sure that absolutly no dust gets through theres always that option!
so,  this is what the material looks like when its behind, its REALLY hard to get a photo, but it does look quite vibrant, once i have the lights in the case, and everything is in place i think they will look rather good!
ive also been doing some spray painting!
one of the radiators are done, is pretty much done (il probably give it another bit of a sanding down and 1 last coat)
ive primed the pump and pump top ready for a coating
and ive sprayed all the fans
Before (a nice mix match of gentle typhoon fans and 1 Enermax cluster, id already done the cluster to see what it would look like
Primed
and.... ORANGE!
ive only actually got 1 week until i need to take this build to i51. 4 out of the 7 days il be working away, so i have 3 days to finish it pretty much. So appologies that this update is a little rushed, and not with great photos!
IM SCARED!!!
