Asbestos in walls or ceilings?
7 Sep 2008
Hey all,
I just bought a house that was built in the 1930s. Lovely property just needs some tlc the plasterboards look old and not been touched in years.
when we showed my father the place he seemed to think that the ceilings may contain asbestos, a quick google search has got me slightly worried.
Nothing came up on the home buyers report - but does anyone have experience in this type of stuff and have a good experience with any particular company who can test this out?
Whereabouts are you? A 1930s house if something hasn't been added over the years won't have much if any in.
Speaking as an Asbestos Consultant I might be some help. Typically in 1930's properties you don't generally find asbestos as they are too old (1960s to 1970s being the worst era) but if it has been refurbished then they may have introduced asbestos products into the house.
What is the ceiling made from? Is it a lath and plaster or ceiling tiles?
You might have a bit if it's ever been artexed.
Otherwise I'm pretty doubtful, you can send some samples off for testing but personally I wouldn't bother unless you plan on ripping down walls and ceilings - asbestos is fine until you start ****ing about with it.
If it's boarded it's not original, 1930's is lath and plaster.
I reckon it is lath and plaster and the house is on the outskirts of west london.
I didnt want to ruffle it too much but it was like cement up there easily broken and penetrated.
unsure if it was refurbished or not after 1930 u see. I've asked local council on their opinion too.
If it is lath and plaster then you're fine. Asbestos was very common in cement for a long period so it could be an asbestos cement ceiling (but in housing I have never seen this so I doubt it)
If you are still unsure then you could take a sample to a lab for analysis (make sure it is a UKAS accredited lab) a sample will typically cost about £10.
If you do get a specialist in be VERY careful of what they tell you. As someone who works in the asbestos industry I can safely say the industry is 90% cowboys who take advantage of peoples lack of knowledge on the subject.
thanks this is what I am worried about....
false information them telling me that there is asbestos when there really isn't just for financial gains!
What you need to watch out for is animal hair in lath and plaster, not sure if it was around 1930's (doubt it) but I've seen some older victorian houses with animal hair.
All kinds of risk with that, anthrax and all sorts.
Was also around from the early 50's,did a house refurb some years ago, once we started stripping it back, we found the original finish, which hadn't been touch in years, there was asbestos insulating board everywhere, a asbestos water tank, & even the old floor tiles were asbestos based.
Even the hot water cylinder which dated from early 80's had a 'may contain asbestos' sticker on the rigid insulation.
You really wont find plaster from that period without bovine hair in. When we did ours it was full of the stuff lol.
If you have house with real old plaster which used bovine,horse hair,etc there is remote risk of contacting Anthrax, even though you had a regulations passed in1907 to control it, it was in-affected until the start of WW2.
http://www.google.co.uk/url?sa=t&rc...woDAAQ&usg=AFQjCNGWQNGK6pXw9RgaereZ63Lv-hbiQA
And another one is arsenic, in old wallpaper & paints, this apparently was also used for treating animal hair used for binding plaster.
yes that is what I am going to do but as MikeRossyBoy said there are far too many cowboys in this industry and I'm not sure who would be trustworthy or not.
I've just had a report from C&N Asbestos Consultancy Services and it read well (for a school refurbishment). They are Essex based.
thanks so I got some quotes from people
the best quote I have got is £150 cash (obviously) and he will give me results within 48 hours
he has some good reviews online - looks like he works on his own too
other companies are a bit more expensive at £200 to £300
too many cowboys right?
