Sorry if this is posted in the wrong location.
I have a couple of WD black drives in my PC basically used for storage now that I have moved over to Samsung SSD's.
I was thinking of buying a couple of external usb drive caddies to put the these WD blacks into, however a friend has suggested getting hold of a NAS box with WiFi. (D Link was suggested) circa £50.
This is all NEW stuff to me, and doing a little Web Window Shopping it looks like I can buy a WD My Cloud with 2tb of storage for a tad over £100. I already have a WD My Book for back up and storage and have never had an issue with it, so I assume that the WD My Cloud would be of similar quality.
I also have a Smart TV so the option of Movies etc direct from a NAS set up sounds good, but it's not vital. Also the option of using the likes of uTorrent direct from a NAS set up without the Computer also sounds good.
ANY help, pro's / Con's would be very much appreciated, however I should point out I do not want to spend mega bucks.
Thanks in advance
Syd
Thanks in advance
Syd
