- 25 Nov 2006
- Ipswich, Suffolk
What do you play on the PS4 Kanifee?
I think the rep system is a nice idea in theory but in reality will mean very little, for example I don't think it made any difference whatsoever on the 360. Friends would just give each other a high rating/positive feedback and that would gimp it if everybody did that.
Plus players would give you bad rep if you were just better than them at a game. I've got bad rep for trash talking on XBL even though I have communication set to friends only![]()
Got my new PS4 today and restored all my saves from PS+ cloud. However, none of them are being detected in any of my games.
Anyone else experience this?
Have you activated it as your primary console ?
Do Ps4's need to be activated as primary consoles like back in the Ps3 days?
Can't remember..
Nope.
Only issue i have with virgin is upload bandwidth, Not much can be done about that though.
Cool, so no issues with the PS4? I was concerned because I know VM throttle P2P connections in the evenings if you go over a certain amount.
Can't remember..
Nope.
“the PS4 has MORE COMPUTE units, and faster memory and a whole bunch of things, that would make that [Xbox One / PS4 parity] physically impossible to happen.” At this point, four months after launch, an increasing amount of data suggests that Gilray is right — and that may be why the PS4 continues to outsell the Xbox One at a rapid clip.
The PS4′s undeniable hardware advantage
upload is 5-12.5 MB which is more than enough for console gaming, in fact with 5MB upload you probably have higher than 90% of other console gamers out there
