http://www.overclockers.co.uk/showproduct.php?prodid=HD-088-HI&groupid=1657&catid=1659
Hitachi 4TB Touro DX3 Desktop External USB 3.0 Hard Drive - Retail
im thinking of getting a couple of these
look easy enough to open up to stick in tower too
i have a few questions after reading comments arounsd the internet
1 theres supposedly a spin down feature for when they arent in use which automatically powers them down... is it on the drive or in the caddy part
ie if one is put inside pc tower will it spin down?
2 are they suitable for running 24/7 inside a media server? or are they far more likely to fail as only intended as backup drives
3 iv read a comment that the drive isnt interchangable between tower and caddy, the enclosure formats it in a weird way and it cant then be removed from caddy and inserted into a pc and be read, it would have to be reformatted... is this true? if enclosure or power supply broke i like to be able to put a hdd in a tower to retrieve data
4
am i better off spending the extra 25 quid on something like a wd red 4tb for use in a computer thats always on
http://www.overclockers.co.uk/showproduct.php?prodid=HD-408-WD
i cant mention competitors but have seen the touro for £106
TIA
4
TIA
They are also poor for use with hardware RAID as they have a tendancy to drop from the array.
