Might trade my 500 up for an 800 if anyone's interested.
Probably looking for around £100 max - got it in the Xmas Amazon deals
I didnt mean that it's not good value, i meant that it may have been more than Grudas wanted to spend.
He said he was thinking of spending 4-500 on upgrading his triban, so i guessed that by putting that money towards a new bike and getting maybe 200ish for selling his triban, he'd have around 700 for a new bike.
I'll chip in more I think, ROSE should be worth it! and maybe replace the FSA chainset in the future with a 105 to make it full-105-grouped bike.
anyone bought from ROSE? how long does the delivery usually take for a bike?
New outer chainring ordered and a few other bits. If my bike doesn't work like a dream after all this expenditure I will be unhappy![]()
Myself and ted_maul (I think) both have Roses.
Rose let you customise your build a bit but oddly that model only lets you swap the FSA compact for a 105 triple. I'm sure if you contacted Rose they might do a 105 compact double.
They build each bike to spec so delivery depends on how busy they are in the workshop. Mine took 4 weeks from date of order.
Need to get some more chain rings ordered too. Mine are completely worn out. I've been looking at the TA Campagnolo ones.
How many miles should you get out of chainrings? My old bike must have something like 6-8000 on them.
My outer seems pretty knackered. I left a chain on there for far too long :/
A friend just a had their ROSE delivered today, a turnaround of just over a month and a half since ordering.
Mine took only 2 weeks. I'm pretty sure they will swap any part you like if you just email them. they were excellent with me with any of the queries i had.
Planet X' hold music is horrible...
EDIT: It turned out to be worth the wait. When my bike turned up on Saturday with that silly looking silver stem, I set up a stock alert on the black ones which it seems were out of stock at the time, and I got an email this morning to say they had some stock in. I called to ask if they could send one out, and I'd send the silver one back, and they said yes, sure, they'd send out a black one and that I needn't bother sending the silver one back. Result!
I doubt I'll even keep the silver one, even as a spare, it is that ugly... ebay ahoy...
Is the Rose that nice? Because you can get Ribble to build you something with 105 for £700ish?
