Spec me a mini rig
10 Aug 2013
Rushden
Hi all!
I recently attended my first LAN party and realised what a massive ball ache it is carting your entire PC from one place to another then back again (my PC is housed in an Antec P280).
While I still want to keep my PC the way it is, I've been contemplating putting together a secondary PC which would only be used for gaming at LAN parties and maybe hooking up to my TV every once in a while.
I'm looking to build a mini-ITX rig, I don't have a specific budget in mind but I would like to keep the cost as low as possible while still having decent performance.
I look forward to seeing what you guys come up with :)
Thanks in advance!!
YOUR BASKET
1 x Gigabyte Radeon R9 270 OC 2048MB GDDR5 PCI-Express Graphics Card £142.99
1 x Intel Core i5-4440 3.10GHz (Haswell) Socket LGA1150 Processor - Retail £134.99
1 x BitFenix Prodigy M MATX Cube Case - Arctic White £74.95
1 x Gigabyte B85M-D3H Intel B85 (Socket 1150) DDR3 Micro ATX Motherboard £56.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £49.99
1 x NZXT Hale Power 90+ 550W '80 Plus Gold' Power Supply £47.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x Pioneer 24x Internal DVR-221LBK DVD Rewriter - OEM £16.99
Total : £590.30 (includes shipping : £17.85).
• Gold rated PSU is made by Superflower
• B85 board has four RAM slots and a VRM heatsink.
• Faster clocked Gigabyte 270 card. It also less likely to leak oil as per thread here.
• Faster CPU;)
I already have an op drive laying around that I can use so I'll save a few quid there. Also, are there any cheaper, but still decent, mini-ITX cases out there?
Is it a SATA interface drive?
There are cheaper cases but most are itX, the spec I did uses a mATX board.
whats the difference between mATX and mini ITX?
The physical size.
A mATX case can sometimes take a ITX board but a ITX case wont take a mATX board.
With MATX because the board is bigger you get more expansion usually such as,
• 4 ram slots vs 2.
• More PCI/PCI-E slots.
• More room for aftermarket coolers.
I currently have a GTX 580 but I'd rather just have a separate build other than my main PC so I don't have to keeping taking the GPU out and moving it back and forth everytime I wanna use the mini one.
Out of mATX and mITX which would you recommend using?
I'm pretty sure it is. I hope this doesn't make me look like a complete idiot but whats the difference between mATX and mini ITX?
I used the Prodigy as it's popular for LANs, it basically has built in carry handles lol They do a mini-itx variant but it's the same size, it's just the internal layout that differs to allow different sized mobos.
I thought the NZXT Hale 550W was a non modular PSU
No hotlinking of images.
I used the Vulcan over the Elite RAM as it had better CAS timings for the same price. Hopefully you are getting a good idea of what's possible for your cash :)
I'm quite surprised how good a build I can get with the budget I said in all honesty! I preferably wanted an Intel based build but didn't think I'd be able to afford so that's a plus :) will a 550W PSU be enough power? My PSU in my main PC is 750W
For that spec a good 500W+ PSU is ample.
Also according to the specs,
NZXT Hale 550W PSU = 45amps on the 12v rail
Silverstone strider plus 500w = 34amps
