Considering I derped so hard yesterday with the title, I figured it best to let you all know that it's ACTUALLY CORRECT today
MSI Radeon R9 290X Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £379.99 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification
- Backplate included: Yes
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1040MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: MSI Twin FrozR Gaming Cooling
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Features
- DirectX 11.2 Support
- Open GL 4.2 Support
- Dolby TrueHD and DTS-HD Master Audio support
- Crossfire Support upto 4-way: Native software crossfire (No bridge required)
- Gaming @ 4k Resolutions (UltraHD)
- Synergy with next-gen game consoles (Mantle)
- Graphics Core Next (GCN) architecture - optimized from previous generation products
Only £379.99 inc VAT.
ORDER NOW
_____
AOC Q2770PQU 27" Widescreen LED Monitor - Black @ £319.99 inc VAT
Experience a new level of sharpness with this large 68.6 cm (27”) monitor. The q2770Pqu utilises a state-of-the-art Super PLS panel with the stunning WQHD resolution of 2560 x 1440 pixels. With its D-Sub, DVI-D, HDMI and DisplayPort connectors, plus speakers as well as a USB hub integrated into the bezel, this energy-efficient display offers you a multitude of applications, delivering exceptionally crisp and vivid images for even the highest demands. Benefit further from full ergonomic flexibility with 130 mm height adjustment, tilt, swivel and pivot (= portrait mode rotation) function. The q2770Pqu comes in a classy black texturised design and features eco-friendly LED-backlights .It fulfils sustainability certificates such as Energy Star 6.0, TCO 6.0 and EPEAT Gold. Let the q2770Pqu impress you today!
Specification:-
- Monitor Size: 27"
- Visible Screen Size: 68,6 cm
- Screen Format: 16:9
- Brightness: 300 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1 (DCR)
- Contrast Ratio Typical: 1.000:1
- Pixel / Dot / Pitch: 0.311 (H) x 0.311 (V) mm
- Display Area: 597.89 (H) x 336.31 (V) mm
- Viewing Angle: 178°/178° (CR=10)
- Response Time: 5 ms GtG
- Maximum Resolution: 2560x1440@60Hz
- Recommend Resolution: 2560x1440@60Hz
- Colors: 16.7 M
- Connectivity: 1x VGA, 1x DVI-D, 1x Display Port Input, 1x HDMI
- Dimensions (WxHxD): 642 x 558 (+130) x 245
- Weight: 7.5 kg
- Warranty: 3 Years
Only £319.99 inc VAT.
ORDER NOW
Specification
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 3yr
Features
ORDER NOW
_____
Specification:-
- Monitor Size: 27"
- Colors: 16.7 M
- Weight: 7.5 kg
- Warranty: 3 Years
ORDER NOW
