Plextor M6e M.2 PCI-E 256GB
26 Jan 2010
ESSEX
Not an expert on SSD's this is my first one, apparently motherboard controller chipsets effect transfer rates.
I ran a benchmark on it and i'm getting 350mb max, is this normal speeds?
Is it a issue with the benchmark/motherboard.
Motherboard is in sig, sorry if this sounds stupid ^.^
e311373563313ab247dde19b3740a667
"edit" http://gyazo.com/e311373563313ab247dde19b3740a667 incase above is an issue.
let me know if this works okay.
does seem a bit slow,idk why though
tried installing latest intel rapid storage drivers? idk if they would work with pcie ssd
latest bios might help
Make sure you have installed it in a physical/electrical 4x PCIe slot. You may have installed it in a 4x physical but 1x electrical so it will only run at 1x. Other than that I would say you have PCIe 1.0 on a P55 board which will also cause it to run a lot slower.
I installed the Intel rapid storage drivers, ran benchmark, same results.
As regards to the bios update, i'm in the process of doing so, but i'm afraid i'll brick my motherboard altogether :S (never updated bios, it's very old according to the asus website)
Expansion slots are
1x PCIe 2.0 x16 (single at x16) <---graphics card
1x PCI Express 2.0 x16 slot (@x4 mode, 2.5GT/s) <--- SSD
Atleast as far as i can tell.
Expansion slots are
How strange. Try swapping your GPU with the ssd and see if it improves things. If it does then it looks like a PCIe bandwidth issue.
you'll be ok on asus board as the bios chips pull out if you need to replace it
just flash with usb stick using ezflash and from within the bios
usb3 sometimes affects sata speeds on p55,but not sure if it also applies to pcie lanes
Finally flashed the bios using ezflash 2, and the results are as follows
http://gyazo.com/1454cbaca8f3d3ad7a1b90c80fefe5a0
Not a particularly impressive result.
Strange, but considering i've updated my OS service pack and bios to practically no avail, i guess this couldn't hurt the process of elimination lol.
Ladie's and gentlemen we have a winner!
Result's after swapping the GPU around with the SSD
http://gyazo.com/7f1f69b7ca1cbf1edf142a1c59fdc939
On that motherboard, with the SSD I would expect those results. Your motherboard is bottlenecking the SSD.
Indeed you were correct, obviously a bandwidth issue on the PCIe lanes?
I take it a new motherboard is in order if i want the full speed of this beast, i guess we can mark this as solved.
I'd like to thank everyone who chipped in their two cent's
Might try fob my board off to my younger brother and purchase a newer board, although i guess that would mean either a newer CPU to fit in the socket or just a more powerful LGA 1156 (socket H) board. :(
Quick update upon further bench marking and general mucking about.
I have come to the conclusion after switching the graphics card around with the PCIE SSD, i lose "no performance" putting the graphics card in the x4 over the x16 slot.
Based off FurMark burn tests, at 15 minute intervals.
I'm not exactly sure what this exactly means? :confused:
That says to me that your GFX wasn't fully utilising the PCI-E x16 lane, but the SSD is doing a better job of maximising the lane speed.
A bit late, but you need to test with a different tool....
You've not lost performance while running furmark as it requires basically no data transfer between the graphics card & the rest of the system so the x4 slot is plenty.
That's why it stresses graphics cards cores so much - and why it's a meaningless test, it's creating totally unrealistic load.
Test with a decent tool/benchmark/game to see how much performance is impacted and never use furmark as it tells you nothing of use.
