I had one, sent it back and got this![]()
So when are you going to buy a proper card again
Booo, ultra/max or nothingHonestly though, sure some I have to turn the AA down to x2 or x4 or just leave it on TXAA. But other than that, ultra settings all the way.
I was going to say Crysis 3, but you probably shouldn't play that it's not a particularly good game. Graphics in that are immense, this was dropping to 30 sometimes for me. Tomb raider and BF4 drop in parts for me, but only to 40 - 45 minimum. Metro 2033 was probably about the same too. But as above all of these are at absolute maximum everything.Name some![]()
That's the problem I have at the moment, I keep uhmming and ahhing about upgrading from my 7970 but there are actually so few games that tax it much @ 1080p. I should probably just back off on the settings a little bit.I don't know if I will notice any difference if I were to upgrade.
Will my 690 cut it?
The HD6950 works exceptionally well if you flash the BIOS, enabling you to unlock the shaders to 6970 level for a count of 1536 and raise the GPU/Mem clocks to 880/1375MHz, before chucking it and getting a 780 Lightning instead!!
Well, it worked for me, anyway...![]()
any other games use nvidias hbao+ how much better iis it than regular hbao which radeon cards are limited too?
I think the previous real time demos were running on 2x 680.4770K and a couple of 7970's
Hopefully it is optimised for multi-gpu's. Usually I would suspect with it being a "triple a" title it would be well optimised and run beautifully on 2 gpu's. But 4 words put the utter shivers up me....
Call of Duty: Ghosts
:O shocking!
This sounds like Battlefield all over again...
Epic engine and sexual graphics. Most of which has now been disabled because it's broken.
I have 780s in SLI so I now officially have the biggest e-peen in this thread so far.
