Chinese Grand Prix 2014, Shanghai - Race 4/19
McLaren arent known for being shabby about in-season development also (especially with RD back in charge)
Unless Renault are allowed to apply a cough reliability cough fix to the engine, RBR will be considerably down on power for the whole season. For this reason alone it wont be as easy as you are making out for RBR to get 2nd
Mercedes ultra short noses has finally passed the crash test on it's 4th attempt.
Apparently some said it would never pass as it's to short.
Can't find any picks atm, going to be interesting. Apparently the nose ends before the main wing plane.
And main advantage is it'll make the car much easier to balance and set up.
But who knows, more should be revealed at fp1.
https://twitter.com/SomersF1/status/456695065943879682
Loads of pics on F1 Technical.
Looks fantastic and what's more, Toto is quoted as saying the old nose was an emergency fix and the entire car has been designed with the short nose in mind. Could mean that engine advantage is going to be compounded with aero that could perhaps rival, or even better, RB.
edit:
Wow, that other pic really shows just how much further back the nose is. I know it's hard enough for drivers to "know" where the front of the car is, but that would make it even riskier to take a front wing off.
Luckily only chance of that at the moment is a Merc. colliding with another Merc. :p
Thanks, hopefully we'll get a technical run down of why it's so good, or at least expected to be so good.
http://img838.imageshack.us/img838/3702/90wi.jpg[img][/QUOTE]
By moving the main structure backwards, they can get away with raising the height of that opening, effectively meaning more air passes under the car, is what I'm thinking.
I'm at the WEC this weekend so will probably miss this, but hey, LMP1 cars whizzing around Silverstone should be good :D
That looks fantastic - but how are they able to get away without a protrusion, I thought these were a pre-requisite?
There are two schools of thought by the looks of it.
1) the front wing acts as part of the nose-cone. Apparently the FIA weren't happy with this philosophy, understandably, so they moved onto:
2) the shorter nose-cone, which obviously meets height requirements (which are clearly laid out in the technical regulations), but the crash test requirements are very specific:
  • The leading 15cm must not exceed 10g deceleration
  • While absorbing the first 60kJ there must be no more than 20g deceleration
That's quite a technical challenge, which, after the FIA rejected their initial plan, took them a while to adapt to get the nose they sought. I suspect the Jerez nose had a lot of the theory of the intended nose applied to it, which is perhaps what lead to it failing so easily on the first day (it's very, very rare for a wing to just fall off a car without contact).
While it seems a difficult task to pull off, if the benefits are that clear, other leading teams have either dismissed it or will be cooking up their own interpretation to suit their car at some point in the future. The nose itself has been known about for a couple of months, so the theory behind it must be well understood by the other teams already - it's just whether it's worthy of them following up against their own very different designs. While some teams are likely to adapt their current noses a little here and there (see McLaren in Bahrain), it's more likely we'll see a more common nose next season, if the current regulations are to stay exactly the same (which given the universal outcry against the appendages, seems unlikely).
What's the access hatch in the front wing for? Ballast? Never even occurred to me to place ballast in the front wing.
Yup. Under the plank, the front wing and the tea tray are the normal locations. Although, it tends to be tungsten rather than lead. Tungsten is more dense, but significantly harder to shape/machine.
A few years back the tea trays on some of the top teams were so heavy that it took 2 people to handle them safely when fitting or removing them from the cars. They were pretty much solid tungsten.
