Mate at work has an Echo with Campag Record and an Etape with Campag Centaur with mudguards......really nice bikes.
Replaced the gear inners and outers on my DA9000 today along with re-taping after the Zipp tape, although lovely feel, was stuck down and took ages getting off....was hoping i could just unpeel it and reuse but no chance.
Got rid of the DA gear outers and Jagwire slick stainless inners as i had used light grease on them last year but over time that has proved to be a bad idea as it solidified and dried up and made the cable run a bit sticky, down shifting was getting hesitant on the rear.
Using Jagwire inners and slick stainless outers and a small amount of GT85 this time, much much lighter action than before.
Bought a 3 meter length of outer from Starcycles on ebay as well as 3 inners, highly recommended source!
Got some black PRO SL tape from Ribble, seems nice stuff with a similar feel (tennis racket handle tape) to the Zipp (which was out of stock) and matches the PRO handlebars and post i have as well.
It was also easy to fit, stretched nicely and the backing was only slightly tackey and gel like so could be removed and repositioned as required (inc in future). Nice.
Also dropped my DA9000 cassette at Ribble due to the creaking, i'd replaced it with an Ultegra and it has solved the problem so its definitely that (also the creaking is all over the internet so a known issue).
They are sending it back to Shimano so we'll see what comes of that....
Called in at Evans at Preston, its a new store so had a look round. could have got some Lizard Skin tape, but already had the PRO so maybe next time.
They had a nice BMC Time Machine SLR01 with DA9000 and DA9000 C24 (same as my Scott) but this was £6k!! Didnt pay anywhere near that for my setup!!!!
