How is a 3 Series Coupe 'big'? A Z4 is 4.1m long, a 3 Series Coupe 4.6m. Not exactly a barge![]()
I was quoting fox stating the coupe is bigger than the saloon.
By less than 3 inches...!I was quoting fox stating the coupe is bigger than the saloon.
Why? It's not like it's going to be a Tickford Capri. Most modern RWD 6cyl cars are in a sense 'unbinnable' - lots of grip, lots of safety systems.+1 for the Scirocco or similar hot hatch. I don't think a powerful RWD 6cyl is a wise choice for a first car.
Thats really not the point dude...
I said i'd like a Coupe because they are smaller than Saloons, which in large part is correct, Fox chooses 3 series Coupe to get a 3 series in there, knowing that I dislike saloons due to their size but in retrospect the coupe is actually bigger then the saloon, regardless by how much size, so either way is just not the kinda car I wanted. Good? Cool.![]()
[TW]Fox;26189958 said:It's generally not correct though, the 3 series isn't a special case, almost every coupe is the same or greater length than the saloon on which it's based, if it's based on one.
They simply have a longer door and longer rear quarter panel in place of the rear door.
The Scirrocco isn't a coupe, it's a hatchback.
If you want something notability smaller than a saloonit's generally going to need to be a hatchback. 1 series coupe is fairly unique in the market.
SLK? It's a small convertible but has a hardtop of course, turning it into a coupe (kind of).
just for the sake of being different a 2006/7 ford mustang. Seriously cool coupe and a stand out first car.
I think a 350 would be fine and i wouldn't be too concerned about the power as a first time driver.
Would I be right in a comparison by comparison basis that the Mercs tend to be higher to service but don't actually provide the ride quality BMW and to an extent say Audi do?
I've been reading the entire internet about cars over the last couple of weeks trying to make the right decision but can always use some confirmation.
I don't own either a merc or BMW but I believe the servicing on mercs can be higher.
I presume you have no children, no major commitments and no requirement to commute.
So as insurance isn't a huge issue, for 12k I'd be looking at a Boxster.
