Got mine finally, NC headset is fantastic. Screen digitiser is noticable at very very close inspection, on par with my other current testers. Anything less than full white screen / high brightness and you can't see it though (well, i can't). It doesn't support exFAT, be ware - if you put an exfat card into it it seems to destroy the FAT table because it's done a number on my 64gb card, i put it back in my S5 and it's moaning the card is dead. Dammit sony.
Anyway, aside from that it's great. I'm gonna recommend people get magnetic cables though if you're like me and find the tabs a bit annoying. I got a Nilkin poly carb case and it does the job nicely for a fiver but I've used them for years so I don't expect less than the best from them. Stock apps are moderate, you can remove about 80% of them, I hid the rest. Can't find the free films though, I want to watch spiderman 1
