- 22 Jul 2012
- London
If it was all on a single loop, I'd agree
Not sure I'd want all the hot air from the gpu's going onto the cpu rad considering the cpu's already doing 68c @stock.
I'd go with option 2, having all that cool air going into the 560 will offer better cooling than cool air going into the 280.
Silverstone TJ11 I believe.
Update us when you have cleaned the blocks![]()
There isn't any airflow path from the lower section into the main case unfortunately.
Dremel time?
OLDPHART's suggestion to have the 180mm fans blowing into the bottom section would probably let you use both rads as exhaust down there though.
The 180 fans are blocked underneath there is no hole from them to the rads area so not really an option unless I start making some very big holes !![]()
So what happens to the hot air being exhausted from each rad into the middle? The psu blocks the other end.
Now moving the fans and radiators is not as simple as it seems !
as when I swap the postion of the rad the fitting coming out and going to the top area wouldnt line up ! (see two pics below)..
first pic shows the pipes coming up far right to the GPU rad and the middle comming back out of the GPU rad..
free upload image
Sorry for my poor drawing showing what I mean about aligning up incorrectly...
img host
+1 personnaly i would cut out holes in the bottom section where the 180mm fans are and do option one.
The hot air has no way to escape so the heat will build up using OP3.
I think it might be possible that our sarcasm detectors may have been malfunctioning there. At least I hope so![]()
