Kiln dried sand and some weedkiller
Planning to dispose of a body?
I work from home
£1 per post I RTM theophany is my main earner
Working from home is fun!!
I'm currently sitting here in my 'Jammies' listening to Harry Potter (read by Stephen Fry) whilst designing a housing for a Photomultiplier Tube in Autodesk Inventor!!![]()
I still haven't tried it, any hints as to what it tastes like?
Joffrey aint so bad, he's a very memorable character haha.
200K on the clock?![]()
How the hell did you get that for 150 euros? Has it been written off? Is it falling apart (suspension)? Does it need the cambelt changing? Does it have no service history?
Even if yes to all the above, that's a cheap car!
I'm not sure when the cambelt needs changing, is there any way to see?
No not really unless you take it off and then you may as well replace it or if there's a bonafide receipt for the work.
They are very well known to throw the belt and lunch the engine which it'll mean scrap heap time for that car.
If you want a reliable motor change it now including the water pump and tensioner.
If you want to risk it then leave it but the risk is total destruction, possibly being stuck somewhere you need to be towed from.
It's got a full years NCT (equivalent of MOT) so I'm reckoning on driving it for a couple months then selling it if it works.
I reckon to change all the stuff is probably going to cost at least 500 euros, which is more than the car will ever be worth?
edit: I can probably get 120 euros in scrap metal for it, should it die a death before the allotted time, which mitigates some of the albeit small outlay.![]()
If you're not going to then keep your ear out for a rattle, the belts very very rarely give way the tensioners fall apart and throw the belt off first.
And if it's a twin spark get used to adding 1ltr per 1000 miles of lovely selenia oilit's 'normal' apparently although some do and some don't, totally random.
ohhh, oil, knew there was something I had forgotten to check.... Never heard of Selenia oil. I'm guessing normal semi synthetic will do as per eurocarparts suggestion?![]()
