I would buy the parts and take it to an independent garage to get them fitted. As for the exhaust I would just get it bodged or welded until you can afford to replace it. It would be a shame to scrap the car.
Where did you get the MOT done?
Thanks for the people who actually had some info and input that was useful...I really appreciate it.
Fact is I was quoted £850 for the Front flexi pipe itself and considering the car is worth around £1500 I was weighing up my options.
Why didn't you mention that in your first post? Because the failures points are all relatively cheap repairs and you didn't bother to mention you'd had a ridiculous quote it's hardly surprising people have questioned why on earth you'd consider scrapping it.
If the handbrake is seized it's not a cheap repair...
[TW]Fox;26219991 said:Erm neither is it open heart surgery. It's a very common issue and is hardly complex or expensive.
You said fixing a seized handbrake wasn't cheap or easy - it is
What are you on about? The "whole assembly" is two brake shoes a spring, actuator and a ratchet - none of the bits that actually do any moving will be broken, even if they were they're dirt cheap
I've already explained how the backing plate can be repaired too
So why were you making totally random statements then? I'm happy to try and help you out/explain things (as I'm sure others are) but come on!
Swirl flaps not sure, few hours I'd guess - say £150-200. Plenty of people have had it done though should be easy to check
